Hi all again! So I sheered the front left rim while plowing snow
See pics attached.
This is a B600DT 4WD model and the rims seem weird . Specs say it should be 6-12 in front and 7-16 in the rear. Given the mangled front I measured it and it is 13 and 1/8" tall rim TDC -> BDC. Tire is just under 22" tall on work rubber. The factory specs from what I have seen indicate just size tire / rim sizes should be diff with same lug pattern.
As a temporary fix to plow out I figured I would just take the front wheels from my B6000E 2WD and throw them on since they are smaller (18 1/2") and will lead (spin faster) and are smooth lawn tires so slip rather than bind the gears . Well? Different lug pattern? Also a 4 lug but about 3-4mm off from the B6000E .
Anyone have an idea wth I am dealing with here? Or have a lead on a pair of rims for the front?
