B6000 ZL600 Crankshaft Removal
provinsm
B6000
Herefordshire, UK
I'm trying to remove the broken crankshaft from an ZL600 engine (B6000). Could someone guide me through this process?
It's completely stripped down apart from the crankshaft and main bearing not sure what's next.
The plan is to take the engine to be inspected.
I cannot see any other obvious damage and i plan to get a complete overhaul kit.
all advice welcomed!
rentthis
1,010
25
summerville,sc
At this point, what you desperately need is a workshop manual. It will lead you through disassembly and then assembly.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
Williamstown Ontario Canada
If you are taking the engine to someone, they likely would prefer it as assembled as possible so the parts can go back in the correct location and orientation.
No mechanic likes to be presented with a basket of parts to make work again.
For reference:
This link will take you to a WSM for engines. I see in the list, second from the bottom, 70mm engines which include the Z600.
http://kubotabooks.com/AutoIndex/index.php?dir=Engines/&AutoIndex=4b0292f4fac17d2b0eb3e131018e4ba4
This link will take you to a WSM for a B6000 including the engine.
http://kubotabooks.com/AutoIndex/index.php?dir=Tractor Owners Manuals/
Dave
