K khofmeister New member Equipment B6000, tiller, loader Dec 18, 2015 7 0 0 Ojai, Ca Dec 18, 2015 #1 Attempted to engage 4x4 but it doesn't work. Same with the PTO.
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,376 2,184 113 Bedford - VA Dec 18, 2015 #2 khofmeister said: Attempted to engage 4x4 but it doesn't work. Same with the PTO. Click to expand... When you engage it - work the clutch a bit.....ride the clutch, as you "try" to push/pull the handle - find that spot where it will grind and then see if it will engage
K khofmeister New member Equipment B6000, tiller, loader Dec 18, 2015 7 0 0 Ojai, Ca Dec 18, 2015 #3 Will give it a try. Thanks
S sitdwnandhngon New member Equipment B7100 Aug 25, 2015 45 0 0 NY, USA Dec 19, 2015 #4 Is there a cover on top of the transmission you can pull to inspect the gears? You will need to drain the transmission to see all the way down, you can work the 4x4 and PTO levers and see which gear is screwed up.
