B6000 FEL Pump Replacement and chatter
warmblood58
B6000DT
Dec 28, 2022
77
20
Jacksonville Oregon
Yesterday, after loading up my bucket with 5-6 loads of 3/4 minus, I started to get some pump chatter (cavitation?) I noticed that my return line (low pressure) was twisting and reduced a little in diameter due to air/diminished flow (?) More importantly, my return line has some excess and had a pretty good belly in it from not being routed correctly so today I am going to reroute to get it level and remove that belly which should help. I have new universal hydraulic fluid in this system which should be fine vs ATF or 30 weight motor oil (it's a 70's machine). Yesterday's experience prompted me to think about pump rebuilding/replacement if this ever comes to be. Are these little kubota pumps rebuildable/replaceable or is there a better update for these pumps that works?
7,344
They are gear pumps and not rebuildable.
I think I would be checking suction side strainers and filters....
warmblood58
B6000DT
Dec 28, 2022
77
20
Jacksonville Oregon
Thanks Dan, Suction side strainer was removed a few months ago on this new to me tractor because it was old and damaged - hydraulic shop felt it was no big deal to run without strainer temporarily until I installed 20 micron spin on filter setup -fluid is all new. My pump is driven off a pulley up front off engine.
7,344
You have a 20 micron filter on it now ?
warmblood58
B6000DT
Dec 28, 2022
77
20
Jacksonville Oregon
On a system like that its easy to watch the flow. Remove the tank return and hold it over the tank filler with the engine running.
Thanks, and that was a 10 micron - just added about a quart and a half of fluid so that with both rams all the way in, there is about 4 inches from breather - noise has gone away, and I resupported feed line with different routing which also took out the belly in that line (removed about 7 inches of excess line - seems nice and quiet - will report back after duplicating yesterdays work-thanks
warmblood58
B6000DT
Dec 28, 2022
77
20
Jacksonville Oregon
warmblood58
B6000DT
Dec 28, 2022
77
20
Jacksonville Oregon
All good! Removing the excess line and supporting it (no belly) and adding a quart of hydraulic oil made all the difference. I believe the fluid was getting hot and aiding in the line belly with sag from heat, supporting it made a huge difference and I believe when I refilled reservoir originally, I still managed to undershoot the proper amount (added about a quart). I worked the FEL hard yesterday, no chatter, pump nice and quiet!
