I'm about to build a ballast box for my b6000 so I can use the loader for lifting heavy materials without faceplanting and so I won't be so tippy on rocky and hilly land. I'm curious to see what opinions are regarding optimal weight and configuration is for such.
There's been a recent post regarding the lift capacity of b6000s here:
http://www.orangetractortalks.com/forums/showthread.php?t=5059&highlight=b6000
In it the lifting capacity for the b6000 3ph is discussed at being anywhere between 300 and 800 pounds. I understand that the primary difference relates to the distance away from the lower end eyeholes the weight of the attachment is centered, but am happy to hear anyone's insight into the matter.
I'm using 1/2 inch eyebeams that I'll weld together. They're six by six by three feet long and weigh roughly 50 to 60 pounds each. Think stackable leggos.
While 300 lbs sounds like a good ballast, I am curious about whether more would be better. I could easily jump the weight anywhere between 300 and 700 lbs without extending the horizontal weight distribution on a 2x5 or 2x6 configuration. This would put the edge of the ballast at roughly 12 inches from the eyeholes, and I could counter act the steering loss with a bit of ballast on the front bumper. Is less more in this situation?
As to configurations, any opinions regarding a high stack that is short (ie 1x6 light or 2x6 heavy configuration) or a low stack that is long (ie a 2x3 light or 3x3/4 heavy configuration)? I live in a rocky area with hills and tight turns, so stability and maneuverability are both in high demand.
Thanks for any input in advance.
