Hi, recently purchased b6000 w/ fel and backhoe.
I'm want to change and fill backhoe hydraulic fluid. Backhoe runs off a rear pto pump, so not directly connected to b6000 hydraulic system. I read the manual but it really doesn't say what to do.
There is a hole on top of tank with an elbow connected to nothing. I removed it and can fill the tank from the hole.
Should that hole be plugged or it for excess pressure and should just have an elbow connected to nothing? Top pict shows tank with elbow disconnected.
How full do I fill the tank?
Also, how do I drain to change, do I just connect the main line at bottom of tank, that feeds all the lines? Sec pict, shows bottom of tank.
Thanks, all your help is greatly appreciated
Jason
Jason
