B5100 with front PTO
gooseflight
B5100
Oct 13, 2020
Scotland
Hi, I have this model but don't seem to have a switch for operating the front PTO. Where does it sit? What does it look like? Thanks in advance.
torch
Jun 10, 2016
2,822
1,071
Muskoka, Ont.
Unless someone retrofitted an electric clutch, there isn't one. The "front PTO" is an extension of the engine crankshaft. It was used in some cases to run a hydraulic pump (eg: for a FEL) or a snowthrower.
PS: you need 5 posts and then you can post a picture. We might have a better idea what you have if there's a picture.
gooseflight
B5100
Oct 13, 2020
Scotland
Ah, sorry, that's what I mean. There is an electro-magnetic clutch and pulley to drive a belly mower.
torch
Jun 10, 2016
2,822
1,071
Muskoka, Ont.
I think you will have to follow the wires and see where the original installer decided to put the switch.
Aardvark
B5100E
Nov 25, 2009
44
Brittany, France
On mine, a factory fitted one, there was a separate plate mounted below the steering column. An ordinary toggle switch was mounted on it. I can't post a photo because when the second electro clutch failed (repairs or replacements unavailable) I removed all the related parts and scrapped them. I remodelled the clutch and pulley housing as a box to hold scrap metal for weight.
