B50/LX Cab series with “SU” tire size
FeRdA
West TX
So I searched and still can’t find an answer. Has anyone been able to run the SU tire upgrade on a b50/LX cab?
I would like to have a little more ground clearance and more ballast capability. I’m not running a mid mount mower since I have a shedder and a finish mower.
Thanks in advance.
802Driver
LX2610SU 60" Bucket Land Pride54" Box Blade Farm King 4572 Rear Blade
May 18, 2020
125
91
Manitoba, Canada
Thanks in advance.
I'm pretty sure on the "LX cab", you can't run the larger tires because of the mid mount pto structure, the "SU" model comes without leaving more room, not sure, might be the same reason for the b50 as well.
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
306
77
Bagley, MN, United States
My guess is that they did not want to redesign the cab for the LX2610 with the clearance to accommodate the larger diameter tires. I am guessing that the LX2610 cab is mostly the same as the B2650.
