B3300SU front axel seal replacement
538jpmac
B3300SU
Mar 4, 2023
Parker Kansas
I am replacing the front wheel seal on a B3300 tractor. I have it tore down, seal replaced and am now going back together. Trying to get the hub to go that last bit to get past the seal is eating me up. Spent all day working on this. Is there a trick, a secret? Am i missing something?
3,470
I found a portion of the old seal stuck inside the housing which prevented reassembly.
Check to be certain ALL the old seal is removed first. (and if so…don’t be surprised to find you may have damaged the new seal trying to force it…and have to replace it again before reassembly.)
8,785
Some models had 2 piece seals, make sure the whole old seal came off.
