B3030 - Dash Removal - Ignition Switch
mkillora
Snowblower, Bushhog
Jun 18, 2015
Ottawa, Ontario, Canada
I suspect mice have played havoc with the ignition switch on my B3030. Tractor wants to start but when key is engaged and then released to start position, stops immediately. Suspect wire on ignition switch to fuel cutoff solenoid has been chewed. However, can't figure out how remove dash to get at ignition switch.
Any help would be appreciated!
Tractor is 2007 vintage, B3030
IVAN tnst
B7510 FEL, Snowblower, Bushhog, Scraper Box, Grader, 4"wood chipper
Aug 8, 2014
Wasaga Beach, Ontario
I might be late but, I've got a 7510 which is the cheaper version of yours and looking at the parts illustrations it look similar to mine so,
You have to remove the steering wheel then the instrument panel ( small tab on each side) tilt it back and you will see a couple of connectors then once you have that out you should see in side where your switch is.
I hope this help, BTW you should get the Workshop Service Manual from Kubota, I got mine last Friday, cost $140 tx incl and took 2 days to come since the warehouse is in TO for us in Canada, it really worth it.
Have fun,
Ivan
