B2650HSDC remote start install
NoJacketRequired
May 25, 2016
444
Ottawa, Ontario
A couple of points which I hope will build upon some of the excellent information shared in this thread...
Block heater operation...
I preheat my B-series tractors with the block heater any time temps are near or below freezing. It really makes starting a lot easier. As noted by others, the engine is up to operating temperature in no time at all, a couple of minutes. I start the tractor, run it for about a minute at idle, then bump it up to about 1400RPM which really speeds up the warm-up process, particularly for the hydraulics. This engine speed also gets the alternator producing sufficient power to start recharging the battery. The cab heater is producing heat as soon as the tractor is running.
With respect to remote control, aircraft engines are very high-dollar devices. They are air cooled so a block heater isn't easy to accomplish. My new airplane has seven silicone rubber heating pads bonded to various parts of the engine (a pair on the oil pan, one on the oil cooler, and one at the base of each cylinder). My hangar is little more than a pole barn - a tin shed with air flowing freely through it. The engine cowling is wrapped in an insulating cover - before installing the cover I run an extension cord into the heater plug inside the engine bay. This cord plugs into a wifi-enabled 115V wall plug. In turn, the wall plug is wifi-connected to a cellular wifi device. Through a smart phone app I am able to manually turn the engine pre-heater on and off. It works flawlessly in a hangar where there is no other wifi service. With this setup I could run a camera if I chose, or sensors to detect temperature or any of several other parameters.
With this in mind, I would suggest the easiest / most effective / best bang for the buck would be a wifi-controlled block heater to preheat the tractor. If you don't have an easy way to get wifi in your tractor shed, a cellular device is often the cheapest and easiest way to go. Some US cellular providers offer data plans that are extremely cheap. I my case here in Canada I am paying $7/month for my cellular wifi device so it's quite economical since I live eight miles from the airport - it doesn't take many trips in the car to gobble up seven bucks worth of gas!
SidecarFlip
Banned
563
All well and good if line power is available, which, I don't have.
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
From the sound of things though, you are doing fine with the status quo. As long as your tractors start when you need them all is good. Wondering though if your life would be enough easier to get power installed, or put up solar panels and a big battery? I hate the dark which drags on around here in the winter, so electric lights are a high priority.
SidecarFlip
Banned
563
Unless it's dark out, there is always light in the barn. It's a Clearspan Truss Arch hoop building and the cover has a skylight down the middle. Has solar powered ventilation fans too. Have to keep the hay dry and the cats comfortable inside.
Never had a starting issue but would be nice to warm them up without having to go out to the barn and start them manually.
Said before, I basically got 8 years from the OEM Yuhasa batteries and replaced both with Interstate's same as I have in the diesel pickup. Good batteries.
We both live in what I term the 'mole zone' in the winter. It's dark more than light here and with overcast skies in the winter, it's always depressing.
You probably have some snow to lighten things up. We have not had any yet. It's cold though, hanging about 17 here right now and I need to feed stock tomorrow so I'll be loading rounds in the feeders. Filled the stock tanks yesterday. DTE loves us with our electric bill in the winter. Keeping 2 big stock tanks heated is expensive. Typical month is a couple hundred clams.
