b2650hsd Engine oil inlets
retird
loader, box scraper
Jul 10, 2015
15
brownsville,ontario,canada
i have a new 2015 B2650HSD There are two inlets on the engine labelled OIL. One is on the very top and to the rear of the motor it has an orange cap marked OIL. Then on the right side of the motor to the front is an inlet with a grey cap marked oil. Are they both for engine oil?
tempforce
B2650HSDC
Jun 23, 2012
389
bastrop, tx
in your owners manual it should show you all of the details for adding oil and the location of the dipstick, fill plug, drains, ect.
4,547
It's normal for a kubota engine to have more then one place to add oil. Most have one on top of the valve cover, and one down on the side of the motor near the dip stick. Either one will top the motor up. Kubota engines are used for somany different applications. From tractors, to trackhoes, to skid steers and light towers for a few examples. One unit may be easier to top the oil up using the valve cover. Another may be easier to top up using the port by the dip stick ;)
