B2650 Wheel spacers and mid mount mower
Dae06
2019 Kubota B2650 Cab.
May 10, 2018
173
11
Minnesota
I would love to see pictures of 2650's with wheel spacers and a 60" Mowing deck along with pictures of 2650's with no spacers and the same 60" deck. If you're willing please take pictures with the deck up and down to show the available room. From what I have read the mower moves back towards rear tires a bit when lifted???
I hope to get a 2650 (with a cab) soon and want the most stability I can get.
Thanks
Dae06
May 10, 2018
173
11
Minnesota
Well, here is mine with a 60" (RCK60-30BA) mid mount deck and Kubota 1-5/8" spacers on the wheels. I have had no problems with it so far.
Mower Deck Up:
Mower Deck Down:
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
My pictures are in this thread:
http://www.orangetractortalks.com/forums/showthread.php?t=37347
I have had problems. You can use the deck, but you can't lift it high enough to pin it to use the 3 pt hitch without it touching the tire. I have turfs and Kubota spacers. Eipo used successfully, same tires but different rims, giving an inch or more decrease in wheel diameter.
Dae06
May 10, 2018
173
11
Minnesota
With my set up, I have no problem. I***8217;ve pinned my deck up many times and it***8217;s the same spacing as in my pictures. Is it a different model deck? Mine has a cab. Would that make a difference?
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
What are your tires and rims? Can you measure the distance from the top of the rim dead center to the ground on concrete? Do you have ag tires?
I believe we have the same model deck.
Mine is also cabbed. Eipo used this deck on his B2650 successfully, no cab, but also different wheels.
When you set yours up did you follow the specs in the manual for adjusting the turnbuckles front and rear?
Dae06
May 10, 2018
173
11
Minnesota
My tires are 12.4 x16R4. The dealer set my deck up so I am not sure about the adjustments. If I remember. I’ll check the measurement tonight.
emt0423
B2650 HSDC
Mar 8, 2019
Wisconsin
Did your dealer hesitate selling the mid mount mower with the wheel spacers. With the configurator it warns that it's not compatible. I've been looking at purchasing the B2650 and tried to configured it with R4 tires and it always pops up a warning when I add spacers.
Dae06
May 10, 2018
173
11
Minnesota
No, he had done it before on another tractor like mine.
Bob11x
B2650HSD, L3901
Feb 20, 2016
17
Upstate ny
I am going to look at a B2650 with a 72" deck. I have a lot of hills and need at least 2 or 3" spacers. Is this possible? Looking at pics it seems like it would require some major mods to mower castors??
I have a BX25 now with 2" spacers and a 60" deck and it works like a dream.
