B2650 Weight
ibshane
2017 B2650
Oct 22, 2018
Stanwood, WA.
I'm trying to figure out the total weight of my B2650 with LA534 Loader, 54'' Quick Attach Bucket, BB1260 Box Scraper & RimGuard in the rear tires.
Does this look about right to you guys??
B2650________1,786 lbs.
LA534__________474
BB1260_________362
RimGuard_______456
Fluids & Fuel_____100
Total Weight____3,178 lbs
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
Seems reasonable. When I added my machine up Kubota listed the FEL weight without a bucket (since there are different weight buckets).
Freeheeler
b2650 tlb
Aug 16, 2018
706
523
Knoxville, TN
Sounds about right. Only thing that may be off is tires. I'm not sure which tires the main tractor weight is measured with. There is a small difference in weight between the tire types, and being filled, it could be more than a small difference.
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
You dont have the weight of your 54" bucket. That weight is just for the loader.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
Only way you'll ever know actual weight, is to put it on a scale.
Got a trailer? Take it to a quarry or AG Co-Op or recycling center, and scale it.
