B2650 hst with cab. 72" mower deck wheel spacing measurments
barmstro
b1860, b2650, front end loaders, box blade mmm, rear and front snowblowers
Dec 1, 2017
25
minnesota
Hi my first post, after looking on www for weeks about wheel spacing with 72" deck with indus tires. Right side deck up 3 1/2" clearance left side deck up 2 1/2" to loaded tires. Deck down which moves deck forward indicates no deck wheel rotation vs tire problems. I measured everywitch way posible even standing on my head wiggeling my ears. My dealer says he had put them on another tractor se frame tires and deck owner said works great. I am going for 2" on both sides
Put on by dealer. Not sayin i'm just sayin. Fyi
tempforce
B2650HSDC
Jun 23, 2012
387
bastrop, tx
My mower cuts uneven if I use the same holes on each side.
So I use a offset on one side to level the deck with the ground.
(Pins in the next hole)...
barmstro
Dec 1, 2017
25
minnesota
Poor first post my bad. The measurments are horzontal not vertical. Many people have said wheel spacers (increase width of rear wheels for stability) only work with 60" deck. While when the deck is up i expect the mower wheels to bump the r4's with no measurable damage. I also expect greater stability, i do not want my pride and joy on its side. My place is hilly.
Dae06
2019 Kubota B2650 Cab.
May 10, 2018
173
Minnesota
Just checking to see if you found anything out regarding the wheel spacers. I asked the same question for a 2650 and the 60" deck.
barmstro
Dec 1, 2017
25
minnesota
I do not know, but I thought wheel spacers were a no go with the 60"MMM I do know they work fine on my B2650 with the 72"MMM I am happy with the added stability on hillsides. Loaded rear tires also,,,,, Is it a combination of the 2" spacers and me more accustomed to the Tractor? Perhaps, I am glad I added the spacers and would do it again.
justa livin the dream
Dae06
May 10, 2018
173
Minnesota
On the Kubota site they say it's a "No Go" for both the 60" and 72" mower decks, but I'm thinking that is not correct. You can vouch that it works for the 72".
