B2630 2010 NO KEY IGNITION
Skale
B2630
Nov 28, 2026
Holland oh
I have a 2010 B 2630 with just over 700 hours.
I use the tractor for about 1 hour on a Friday, went out next day to start the tractor and while everything powers up, I’m getting no ignition to my starter, I checked safety switches. I’ve since replaced the OPC relay thinking that had went bad. I’m getting power to the relay. It does not seem. I’m getting power past the relay to send to the starter.
using a power probe and simply testing continuity, I can send power to the trigger wire of the starter. If I bypass the relay switch it almost seems like there’s some other safety or something else that will not allow the key to send that engage power. I’m pretty stumped. I’ve checked all fuses still again. Cannot find a fix.
need help
Skale
B2630
Nov 28, 2026
Holland oh
If I use a screw drive or jumper wire from the hot of the starter/battery I can start the tractor and it will stay running, the key turned to in the off position will shut the tractor down. (Must be on like normal to stay running so key seems to be working .
11,566
Turn the key to crank and while holding it wiggle HST the pedal back and forth.
And while doing that engage and disengage the PTO and the PTO selector if equipped.
Also try range lever.
