PLEASE HELP if you can
Had a problem with starting , really cold yesterday almost started then nothing when I turned key ,tried to jump across solenoid . a large clack ...pulled starter had it tested ..not good . bought new ...installed turn key ...no lights nothing jump at solenoid turns over good but won't start...glow plugs are not working I suspect if no ignition /dash lights changed all fuses in box on side of motor (none seemed burnt) still nothing doubt if it is a safety switch as I would think dash would light up but no turnover ???
Any ideas folks? if there are numbers( 8230) in this please ignore not sure why Thank you
