HI All!! looking to add a 12v accessory outlet on the right rear fender. Got the wire harness and found the red wire with black stripe which is key switched. This connected back into the harness and goes....? Is the proper way just to run new wires to the fuse panel and avoid the wire harness? Will be powering a small garden 12v pump for spraying.
