B2601 with LIMBSAW
bluetec
B2601, Land Pride grapple, WoodMaxx tm-68 chipper, FEL, 54" Land Pride rotary
May 25, 2020
North Carolina
Has anyone mounted and used a LS8 LIMBSAW with the 2601 FEL?
5,128
933
Limbsaw requires a hydraulic flow of 7 USGPM.
Your tractor can deliver a theoretical max flow of 8.3 USGPM at full engine rpm.
Your tractor, as an open center style hydraulic system, may reduce or almost stop flow to the Limbsaw any time you move the FEL.
Suggest you talk to the manufacturer to fully understand what you can expect from their product on your tractor as running at almost full speed to satisfy the saw's hydraulic needs while trying to trim will add challenges.
Also talk to manufacturer about possible hydraulic system overheating if saw used for prolonged periods. Your system does not hold a lot of fluid.. 12 quarts
