B2400hsd power stearing
thollywood
MacClenny, FL
I need a power stearing box for a b2400hsd. The one i have has a worn main shaft. So a bearing and rebuild wouls not stop a leak. Or i need a shaft if anyone knows where i can ger one. The inside box shaft. Not pitman or stearing wheel shaft. Thank you. Tried to get an afertmarket one...none around. Any help would be appreaciated.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Can a machine shop weld on new metal on the shaft where it is worn then re-grind it to the appropriate dimensions?
