I have a B2400 with HST, about a 1998, about 700 hours, used mostly for mowing. Do some front loading a bit mostly lifting logs, tend brush fires and general work round the house, live in a forest so have a lot tree work going on.
Well it just started loosing power and wanting to stall the other day, like an overheat problem. Temp gauge says it is fine. So cleaned radiator, engine, and replaced coolant, changed the air, transmission, & fuel filter. Bleed the fuel line at the three injectors and the pump. There was no air in the lines. Oil looks good, did not mess with it. Still wants to stall after running the mower about an hour, push in clutch to release the load and it takes a few minute to recover so that I can get it back to the garage to try something else. Now I am at the end of my thoughts.
Mower deck is clean and can turn it by hand. Started the same symptom when using the loader to move a log.
Fuel is clean with no visible indications of water in the filter bowl or tank.
could use your help
