B2366 SSQA Adaptor - Universal?
Tioga Tim
B2620
Nov 11, 2020
42
Upstate New York
Any chance anyone has installed one of these to convert their loader from pin-on bucket to SSQA bucket/forks, etc? I am considering going this route but want to confirm I would not be forced to only use Kubota attachments - that the adaptor is universal and will work with any generic SSQA bucket, forks, or other attachment.
Thanks!
Hkb82
Nov 17, 2021
418
330
Ontario Canada
I don't think Kubota has a proprietary ssqa setup but maybe include the part number and a link or photo to the actual part your looking to buy for your tractor.
biketopia
Feb 15, 2024
373
378
Warrenton VA
Any SSQA impliment will work. John Deere has its own quick attach system and then there is the mini quick attach but it's significantly smaller and used on things like a Toro Dingo.
My loader has the SSQA attachment and the only front end accessory that is Kubota, is the bucket.
Tioga Tim
B2620
Nov 11, 2020
42
Upstate New York
Thanks for confirming! Did you modify your bucket with the weld on bracket or did you simply get a new quick attach bucket?
Tim
Tioga Tim
B2620
Nov 11, 2020
42
Upstate New York
biketopia
Feb 15, 2024
373
378
Warrenton VA
Tim
My tractor came with the SSQA from Kubota, I did not modify anything.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
523
208
CNY
Tim, the SSQA adapter "should" fit any SSQA attachment made. There are variations in tolerances so some may fit tight and some loose. The locking pins are tapered and spring loaded so they should accommodate those variations.
