B2320 Won't Move
Lime
B2320
Apr 12, 2018
Lebanon, IN
I have a B2320 that has given me no problems. However,yesterday it wouldn't turn over. After checking some of the obvious things I disconnected the safty switch below the seat. It started. I turned it off very happy with myself. However today I went to use it and it started but now I tried to move with no luck. When I step on the forward(front) pedal and reverse (back) pedal I can hear the engine undergoing a slight load. Or maybe it's the hydraulic pump. I would appreciate any help and advice.
5,255
1,058
Don't know your tractor so you can decide how to accept my suggestion to make certain there is not a hi low range gear lever in a middle position because you hit it working on the seat. It is like a neutral position by accident not design
Missouribound
Jun 17, 2014
668
62
Missouri
1. Check the gear lever.
2. Check the brakes.
3. Check your fluid level.
4. Call your dealer.
7,006
sounds like the safety switch under the seat to me. It doesn't use the seat switch to start, but it does to move (operator presence). So, check it again (you may need to jump the wires) after checking to see if the brakes are on.
Lime
B2320
Apr 12, 2018
Lebanon, IN
Thanks I'm able to do everything needed. I'm not sure what the problem was b ut I did reconnect the seat switch and the other recommendations by the group. Not sure what the problem was but its fixed. Thanks
griffin800
Kubota bx23s, Simplicity Conquest
Apr 7, 2018
Rockford, IL
You can jumper out the safety switch (not advised) and it'll work, you can't though just remove it. Have to complete the circuit.
