I've been reading up on all the posts related to doing the initial 50hr maintenance and have been intrigued with the shop vac oil trick. After reading about oil getting sucked up in vac, and what hp to limit to, etc., I decided that I needed to provide a way to vary the amount of suction. I used a clear 1"ID tube and some fittings so I could see if it was sucking fluid. My shop vac is home made from a whole house vac system motor, so I have no clue as to the hp rating. I started with valve wide open, then closed off about half way. No oil and only oil in filter was lost. Very happy with results. BUT......I noticed the oil was just a slight bit brown, which surprised me, because when checking trans level, it's always been so clear it was difficult to see. Will probably call my dealer Tuesday to run it past them. Should I expect to see crystal clear fluids?
