B2150d transmissions
furbody
B2150
Nov 2, 2019
Mtn home ar 72635
Ok, I have B2150D that I bought new in 1994. Today I went and got firewood in the bucket. I always shift into creep mode so I can get close to where I unload wood, backing out I shift back into midrange,, the transmission would not shift into low gear, but would into second, which it stalled the engine when clutch was release. I started it back up and tryed shifting to low, nothing. Went back to second gear and it lunged forward but was making a horrible noise under the tractor. So I attempted shifting back to low nothing, so I shifted to reverse and it ran fine so i dobe it back to its parking spot in reverse.. any suggestions
8,459
You've dislocated the shift ball in the shift forks.
Pull it apart and realign the forks and the ball.
furbody
B2150
Nov 2, 2019
Mtn home ar 72635
Ok, my 1994 B2150D, that I bought new transmission will only go in one gear, I unloaded a bucket load of firewood, took it out of low range back to mid range back up. Then put in low gear and nothing, went to second gear and it stalled the engine, got it to move about 3 ft with a load clanking noise, so I stopped put in reverse and was able to go backwards with no issues. Once I got to where I park it I tried first again nothing, then second and nothing 3 rd it would go but now no reverse. I’m stumped any suggestion. Fluid levels good. Could a bad clutch be causing it. It’s never had a new clutch with 1600 hrs on it but hard hrs.
Thanks any help would be appreciated
8,459
Most likely not a bad clutch but shift linkage as I stated before.
Do you have the WSM (aka Service manual)?
If not just ask and I'll help you out.
