B2150/LA350, discontinued hydraulics?
Deezuz
B2150HSD
Nov 1, 2022
Nwi
I belive my detent is bad on the control body for the bucket lifting...
Kubota says the detent kit and the entire control valve are discontinued with no part super session...
Help?
Thanks.
My Barn
Kubota, Ford
Sep 14, 2022
135
37
Wow, I couldn't get a swing cylinder for my Kubota backhoe...Had one made. Never had problems like that with Deere or Ford?
whitetiger
Nov 20, 2011
3,186
1,604
Kansas City, KS
You will run into the same scenario with Deere, Ford, or any other manufacturer.
Deezuz
B2150HSD
Nov 1, 2022
Nwi
Sooooo
I can't be the only one this had happened to.
Anybody have any recommendations on aftermarket direct swap?
Vigo
B6100, B8200
Jan 9, 2022
595
341
San Antonio Texas
Wait, is the only thing wrong with that, that it doesn't stay in float? The ball disintegrated?
Honestly, if that were mine id just clean that up, find a new steel ball and a spring (if the spring isn't still there..), and put it back together. It doesn't look that bad to me..
5,291
Sooooo
The parts manaul shows two different handle options for the loader valve. One is cable operated with remote joystick and the other has the joystick handle on the valve itself. Which do you have?
Deezuz
B2150HSD
Nov 1, 2022
Nwi
The bucket does not lift.
First the float stopped working. Then the bucket raise got suuuper slow so then nothing at all. I then switched the hydraulic lines to proof out the cylinders and it lifts fine now... The spool does not go all the way down...
Deezuz
B2150HSD
Nov 1, 2022
Nwi
I have a single joystick
5,291
Its not worth fighting with. Put a new valve on it.
Vigo
B6100, B8200
Jan 9, 2022
595
341
San Antonio Texas
If those videos were taken before you took the float assembly thing off the end of the valve, the most likely thing is just that chunks made their way behind the detent rod and were keeping it from moving fully to the raise position. Try to lift the loader with that cap thing removed from the valve assembly. If that doesn't change it then yeah, i am ok with TOH's 'not worth the fight' assessment in your situation.
Deezuz
B2150HSD
Nov 1, 2022
Nwi
Based onthe component breeakdown it looks like the OEM valve had a fourth float position on the boom and a fourth regen position on teh bucket. Do you want to preserve the regen function or can you live without it?
What is regen function?
Deezuz
B2150HSD
Nov 1, 2022
Nwi
Correct. As I removed the detent cap, the spool/cylinder had full travel within the manifold/block. So my binding is on the cap, and even after I cleaned it.
