Hello everyone,
This is my first tractor and I know very little about them at this point. I am a halfway competent hobbyist auto mechanic, but I know only what you can learn in a day about tractors and hydraulic systems. The tractor has 1600 hours on it and appears to be very well maintained. PO just completed a clutch job, but claims to know nothing about the problem that I am now experiencing.
The Problem:
The tractor can barley get out of its own way. Only drivable in low range (with throttle pegged), med, you can baby it on flat ground to get it going, high, not going to budge. FEL has tons of power, 3 point and PTOs work fine too. In low, I can sometimes just barley get the tires to spin in the mud, but if there is traction and resistance is met, I get some whine and then power just disappears. With my instinct and limited knowledge, I am worried the HST drive pump (??? thingy with the two pumps, swash plates, pistons, etc) is toast. Hopefully it is something much more simple and cheaper to fix. Other thoughts were high pressure relieve valve opening too soon, or speed control pedal/neutral holder out of whack because the pedal feels sloppy and doesn't like to return to neutral, but what do I know. Looking forward to reading your thoughts and advice, thanks in advance.
The Problem:
