I am new to this forum and need help with my B2150 I purchased recently. It is leaking fluid on the right axle. See attached photo. Anyone familiar with fixing this leak and know what is involved? I found a similar post for a different tractor but don't know if it applies to mine. I don't what to take this apart and then find out I can't fix it.
Previous post by 'eserv':
Simple! Remove the seal cap on the bottom, remove the snap ring, shims, and lower gear with it's bearing, remove snap ring up in there on the inner bevel gear case and the outer bevel gear case will all come down exposing the seal. pry out the seal and the seal sleeve. Reinstall the seal and sleeve with dielectric grease, reassemble. ( you'll probably need a new lower seal )
If you use dielectric grease you can push the seals into place with your fingers!
Does this apply to my tractor?
