B2100 D Newbie question
KM4UJI
Kubota B2100D
Mar 15, 2023
Naples Florida
Hello
I have run into a big issue for me at least. I have a Kubota B2100 D and it has turf tires on it which is great for when I use the mid mount mower but when I use the loader bucket or 3 point tools on soft sand or mud. I have contacted Messicks and several other dealers trying to purchase a set of front rims and they all have informed me that Kubota no longer ships tires or rims for that model and I will have to find them elsewhere. I have tried and I can not find any. What I am trying is to have a spare set so that I can do easy switch outs of the front tires as needed. Right now I have what are mounted on the front show kenda brand 21x7.00-10 and rear mounted with good year 31x15.50-15 NHS . Help!
Shadetree605
kubota b2100
May 1, 2022
231
117
north little rock, ar
Hello
i have a b2100 4 wd model, and i just went through the process of switching out my turf tires to ag tires. i do not know the diffence between your model and my model ?, but it would seem to me they are about the same ?. maybe ask messicks if you can run the rims that fit on a b2100hst 4 wd model ?. my b2100 calls for 12x5 front rim, and 16x8 rear rim. the front tires i put on the front rims are 6-12, and the rear tires are 9.5-16, both front and rear tires are carlise farm specialist. heads up : you can not run a ag tire on turf tire rims !, you must use the correct rims for ag tires when swapping from turf tires to ag tires !.
9,781
Hello
You can NOT just switch the front tires without switching out the back too.
The ratio will be wrong and you will damage the front drive.
