C Cloud New member Equipment Kubota B20 Aug 5, 2014 22 0 1 Dalton Gardens, Idaho Aug 28, 2018 #1 The lift and lower on my front bucket has quit working properly. It will only lower when I engage the bucket curl or dump. When I try to lower it without engaging bucket it won't go down. But it will drop if bucket is engaged. Any ideas? Thanks
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 34,579 9,802 113 Sandpoint, ID Aug 28, 2018 #2 Greetings from just north of you. Sounds like you have a problem with the linkage for the joystick. check that out first.
