B1750DT Split
slevys95
B1750, BX2370/wmid60" deck,loader,brushhog,backblade,3pt rear snowblower
Sep 21, 2017
17
Western NYS
Anyone have experience splitting a 1750B. Have a shaft issue, rear PTO stopped turning. Found what looks like eclip off end of overdrive shaft and couplings. Splitting it at tranny below hydraulic pump. Have body apart and elec and hydraulic disconnected. Bottom is pulling apart but can't get top of mating surfaces to separate.An
Sent from my XT1585 using Tapatalk
9,729
Re: 1750B Standard shift split
There is no 1750B Kubota.
Is it a B1750?
And if so is it a B1750 gear or a B1750HST?
By the title I would say geared.
2wd or 4wd?
You can't be splitting it at the hydraulic pump, as that's attached to the back of the injection pump on the engine.
Do you have the WSM for it?
slevys95
Sep 21, 2017
17
Western NYS
4wd B1750 standard shift. Sorry , I said pump but is probably valve for the three point pump. Yes just got service manual. Was on backorder.
slevys95
Sep 21, 2017
17
Western NYS
Thanks in advance for any info
