B1600 lower linkage length?
Michbeck
B1181, G23 HD
Sep 29, 2011
80
Austria, Upperaustria
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
Hi folks!
I am looking for a 3 point linkage kit for my B1600. Now I am not sure which length the lower linkages should have.
My rear tires are 22". On ebay is a long version available with 23,6 inch linkages. Would this fit on the B1600?
http://www.ebay.de/itm/Dreipunktkit-lang-Kubota-Yanmar-Iseki-Hako-Holder-/260896427185?pt=Ersatzteile_Zubeh%C3%B6r_Landtechnik&hash=item3cbea38cb1
If a more definitive answer does not come along, You can get an idea of the length you need by,place a straight edge across the circumference of the 2 rear tyres at the furthest point from the lift arm pivot and measure that distance.add a couple inches on for clearance and that should give you some idea.
Dave
bruceatlam
B20, FEL, box blade, flail mower
Aug 20, 2009
410
Camarillo, California
I'll attach what I have for 3 point hitch design standards. These standards say that the distance form the tip of the PTO to the center of the rear lower ball should be 500 to 575 mm. Measure the distance from the tip of the PTO shaft forward to the center of the mounting point on the tractor for the forward lower ball. Add that dimension to 500 mm to get the shortest lower link length and then to 575 mm to get the longest. Check to make sure it'll clear your tire -------
