B 7000 glow plug indicator
150baker
bucket and back blade
Jan 15, 2011
52
Centerville WA
My glow plug indicator in the dash is only visable at night.
During the day if used I cannot see.
Do I need a new indicator?
If so is the B7001 a match?
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
Get an LED (12v) from radio shack and wire it into the glow plugs. Just hook the positive lead of the led to one of the glow plugs and the other led wire to ground. The light comes with it's own houseing, I think a 1/4 hole drilled into the dash ,( I put mine right next to the old indicator), when you hit the glow plug switch, bright light. You can get red or green.
Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Dec 28, 2010
533
81
Mount Vernon, Ohio
The indicator on my M4500 is the same way, normal old age stuff. I think it is mostly a build-up of dust/grime burnt on to it that causes it to be that way. Keep meaning to try and gently clean the filament somehow but have never gotten to it.
kubotasam
Apr 26, 2010
1,209
132
Alfred Maine
This is sound advice as long as you do not make the mistake of removing the origional Kubota glow plug indicator. If the origional is bypassed you will get to much voltage to the glow plugs and you will burn them out. The OEM indicator is a resistor to drop the 12 volts from the battery down to the operating voltage of the glow plugs.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
When I bought my first B7100 nearly two years ago it didn't have a glow-plug indicator but kept on using it by giving it heat for as long as I deemed necessary.
When I finally looked to see what the problem was I could see the coil was burned out and the two wires were on one terminal to give power to the plugs when the switch was in heat position and I have still not bought a new indicator.
I may be missing the point here but does the led intensity alter with how hot the glow-plugs are like the original coil indicator.If it does ,great i'll fit one but if not then I can't see me going to the trouble of wiring and drilling for a light just to tells me the ignition switch in the heat position.
Dave
kubotasam
Apr 26, 2010
1,209
132
Alfred Maine
The LED indicator will not change intensity. It will just glow when you apply power to it. As far as having the original coil resistor type bypassed It is my understanding that 12 volts from the battery can cause the glow plugs to overheat and burn out. However I guess you say yours has been that way for 2 + years now so maybe I am wrong.
Odever
Washington, WA, United States
Yep. Kubotasam is onto something. The glow plug indicator is more than a 'handy' light or cigarette lighter!
It's a resistor coil designed by NGK to deliver the correct current to the glow plugs. Depending on your model of Kubota tractor, the resistance coil in the glow plug indicator will vary and replacing it with the correct part is essential in aiding cold weather starting and glow plug longevity.
Here's a link to NGK's site explaining how to correctly test the glow plugs in your Kubota.
http://www.ngk-dpower.com/index.php?id=31&L=2
I need a plug in indicator for my cigarette lighter. where i can get this please give me some idea about that. i am trying to make some business with this. hope i can get this field here for my easy access.
8,713
What are you trying to do, your post is all over the place!
Are you trying to replace the glow plug indicator that is NOT a cigarette lighter?
:confused::confused::confused::confused:
