Aux Power Plug for L2501
DavyW
BX2370, Z422 and L2501
Aug 29, 2016
26
Newport, NC, USA
I just bought a new L2501 and would like to run my Fimco sprayer on the 3tp hitch but it appears the L2501 does not have an aux power plug. Just curious, am i just missing seeing it and if not any suggestions on the best way to add one?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,993
2,363
Western MT
There is a pigtail “plug” for worklights under the left fender. At least, I think left if not look under the right one. There isn’t a switch, but it is only powered when the key is on. If I remember right it is fused 10 amp circuit.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
Jim is correct, the connector is tucked neatly into the wiring under the left rear fender. It is intended for a work light and is hot whenever the ignition is turned on. The fuse is indeed ten amps and labeled in the fuse panel as work light.
DavyW
Aug 29, 2016
26
Newport, NC, USA
Thanks for the feedback...That will make it easy to install on AUX power plug....
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
If you need more than 10 amps you will need to connect to your battery, if so this should help
