I just bought a new L2501 and would like to run my Fimco sprayer on the 3tp hitch but it appears the L2501 does not have an aux power plug. Just curious, am i just missing seeing it and if not any suggestions on the best way to add one?
Thanks for the feedback...That will make it easy to install on AUX power plug....Jim is correct, the connector is tucked neatly into the wiring under the left rear fender. It is intended for a work light and is hot whenever the ignition is turned on. The fuse is indeed ten amps and labeled in the fuse panel as work light.
