Re: assemble zextel 3 cyl inj pump Solved
Thank you The Pump Guy, TPG!!
thepumpguysc@aol.com
I was close to the solution but followed TPG's instruction. TPG came through and confirmed it. I recommend and will definitely use his services!!
The pump Guy (thepumpguysc@aol.com) hooked me up to get her running. When I'm done proving the engine I will send him the pump to rebuild. She runs good but is not calibrated. His answer below.
With TPG's permission I give him a plug.
(TPG) "The problem is.. your missing 090.. its a small assembly pin that centers the barrel into the flange for proper alignment.. and it goes away from the rack.. along with the plunger."
(Me)I have no pins and my barrels were in all different directions.
(TPG) "The plungers go in.. slot/helix opposite the rack.. and MUST move freely, with the slightest touch of the rack"
(Me)The grove in the barrel also faces away from the rack, and is aligned with the pin, which in my case is only used during assembly, which was my problem.
(TPG) "Once you loosen the top nut on those pumps and they don't have a pin in it, your screwed..!!!
OR if it HAD a pin in it..once you remove the barrel, the pin falls out and your screwed.."
(Me) In my application I used a .08 drill bit ..
(TPG) "just swap it from 1 to the other (drill bit/pin), AFTER tightening the top nut [delivery valve holder] to 30-35 ft lbs..
The only problem I see with that is>> you see the flange is slotted, where it tightens into the main housing.. with 2 screws.???
THATS the EQUAL DELIVERY setting for EACH cylinder.. if you don't have that set correct.. the engine is going to skip BAD..!!!
That's why I have a 85K $ test stand to run them on..
Thank you TPG awesome help and great service.
Daniel Kozak
Social Circle, GA
