retiree-urgency abandoned
B3350, Kub. 5" rotary cutter, LP 48" forks, Titan Aerial Platform, KK XB Dump
I've already posted about FEL pins falling out and my fix at https://www.orangetractortalks.com/forums/threads/fel-frame-mounting-pin-fell-off.62803/#post-627946.
Today was a perfect day to bushhog a field and after a few hours of mowing, I noticed that the rotary cutter wasn't hanging straight. Turns out that the retainin pins at the right end of the support rod for the 3PH lifting rods had fallen off, the support rod (red line in photo) had slid out to the left leaving the top of the right lifting rod (of course, the more expensive adjustable one) supported by air. It got bent at the bottom. A video of me wrestling with it and trying to remount the rotary cutter in the field would have been entertaining, but I finally got it back on and bushhogging continued. I'll deal with the bent lifting rod when I'm done bushhogging.
I've concluded that while removable pins are convenient if you're often changing setups, I never change my setup, so it's time to harden my pins by replacing them with something that won't fall off during normal operating (which includes bouncing around sometimes). Once I've finished bushhogging, I'm going to end to end replacing removable pins - either with bolts and nylock nuts or with the good old pin, washer and cotterpin bent around.
I've been pretty lucky so far, but I'm not going to tempt fate going forward!
