An the saga continues
5,633
OK yall know the BX came home,,, Now on to the next problem at hand. I know I know I know,, but hear me out. While the BX was down I went and took the FEL off the B pretty straight forward, right? Nope not so much, the feet that are suppose to hold the FEL up collapsed yes they just folded right back in the closed position,, most likely my fault, but I digress. I did manage to get all the hydraulics disconnected, and the arms off the front tires so everything is laying on the floor. So now I need to figure out how to get the grapple off , thats a couple hundred pounds I dont have to fight with, and raise the arms up to where they go,,,, You have no idea how many naughty words I have invented. So at least one of the steel lines has been crunched and is leaking. Is there and kind of splice I can put in the damaged spots rather than have to buy a whole thing from K ?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,179
1,167
E.
Fwiw... the hydraulic shop I deal with would run you about $4/ft to reproduce the metal lines off a L series so pretty cheap when they bend to match exactly if you decide to go that route.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,336
859
under a rock
I'd love to someday see pictures of these escapades...
Caden
1979 B7100
Apr 16, 2026
278
149
I'm gonna ask for a picture of this... but can you use the other tractor to lift an maneuver it with?
jaxs
B1750HST
Jun 22, 2023
1,098
823
Me to. He (and unnamed others) might consider selling subscriptions for and annual addition of escapades. I suspect they don't publish pictures here is because they fear one of their tricks shows in background to be stolen. I can say with conviction that no such thieving scoundrels exists around OTT. šŸ˜‡
5,633
Boys if I could do pictures I would some days I swear my wife is just haunting the snot out of me and laffin her ass off ,, and no a video with audio would be one big beeeeeeeeeeep
Orangeglow
2015 BX2370
Jun 19, 2014
418
232
Prescott, Ontario
skeets, if the feet colapsed, looks like you are going to have to purchase a new set, or at the minimum, remove the old ones and have them repaired. Is there any way you can lift the loader with another tractor and keep it propped up with skids or some other means ? If you could do that, it would make it much easier for you to undo a couple of bolts to remove and either repair or replace the old ones. It,s only money, check out how much a new set will cost you. It should be very easy to remove and replace, once you have decided the direction you want to proceed in.
5,633
Yes sir my thoughts exactly , I was thinking about a a spreader so the arms dont flex to much and using the boom crane on the BX left it and like you say block it,, should be interesting
