Hi!
I don't remember the position of the forks when I removed them. The trans was in neutral when I did but I have since moved gears around to get the new reverse gear in. I had them in at one point. But I could not shift the middle gears 1/5 and 3/7. And the pto shifter didn't feel like it engaged anything.
Should all notches in gear shifter be aligned to equal neutral (where the spring loaded cylinder pops into if the shifter is not there?
Where do the pto "forks" go in relation to the pieces they bump against in the trans? Both in the middle? Is neutral for the pto when both notches are aligned?
Thanks for any help.
