Adjustable lifting rod
Smokeless
3901/Loader/Rear Blade/Box Blade/LP Mower/Pallet forks IH M,,Cub & sickle mower
Feb 5, 2018
237
9
Southern Illinois
Does anyone else find the adjustable lifting rod difficult to turn. Specifically i needed to tilt my rear blade to one side to cut a small water drain path in the driveway. Boy that arm was tough to turn. Any tricks out there????
SidecarFlip
Banned
562
Set the implement on the ground and relieve the pressure on the adjustable link. You'll be amazed how easy it turns. Not meant to be adjusted with implement weight on it.
Smokeless
Feb 5, 2018
237
9
Southern Illinois
Well, i did have it down to start with. Still turned very hard. I will try it again tomorrow and make sure pressure off adjustable link, i did not check that first. Thanks.
2,545
Be sure the threads are lubricated with grease also
Tim Horton
291
67
Lake Superior
Like said... Once you get it to adjust, move it to the maximum length and lube well.
I use copper color anti seize compound. Has worked well for me.
Smokeless
Feb 5, 2018
237
9
Southern Illinois
Ok, lots of grease to, copper anti seize good tip. Did not think of that. Thanks
All i know is that link turned mighty hard, i will verify pressure off link, more later and thanks
Smokeless
Feb 5, 2018
237
9
Southern Illinois
BXHoosier
BX24
Jan 21, 2018
502
604
Indiana
Try letting the blade down onto a 4x4 or a couple 2x4s in the center of the blade so it takes the weight off the lift links and allows the blade to pivot on the blocks.
SidecarFlip
Banned
562
Didn't realize you did not have a crank handle. Both my M's have a crank handle on the levelling link (and 2 grease fittings as well.)
Smokeless
Feb 5, 2018
237
9
Southern Illinois
Bingo!!!! Worked great, blade titled from side to side easy with 4x4 in center. I still would prefer a crank handle. Another gent mentioned he had one on his M with two grease fittings. Wonder if it would retrofit to my 3901?
I assume one would use same technique if tilting a box blade.
We are old school red fast hitch people here, even my 300 had a crank handle for tilting..
Thanks for the tip, dont understand why little tid bits like that aren't in the manual
Thanks again
SidecarFlip
Banned
562
Thanks again
That would be me and I bet it will fit. Check with your dealer.
MtnViewRanch
881
328
Lakeside Ca.
Yes it will physically go on, but is way wrong.
Over all working length is much longer on the M, 4" If I remember correctly.
Top pin size is 7/8" on the M, 3/4" on the L. As well as the ball swivels are different widths, close, but different.
Lower pin size is 7/8" on the M, 5/8" on the L. Lower clevis's are different widths inside and out.
Like I said, it will physically fit on, but everything is wrong about it. :eek:
Smokeless
Feb 5, 2018
237
9
Southern Illinois
Well that sums it up. Guess I will head a different route, probably after market retrofit. Thanks for detailed reply.
