Additive
2,831
Cglaza
L2500DT, BX2380, G6200H
Aug 30, 2015
176
Freeland, mi
Typically you should run an additive in your older tractors due to the lack of lubricity in low sulfur fuel. Newer tractors are able to handle the low sulfur diesel because they were engineered for it where as an older diesel experiences more wear in the injection pump because sulfur that is removed acted as a lubricant. I personally use power service. It's good stuff. It's the only additive I've used in the winter where my fuel has not gelled. (I drive semi for a living) For summer time, you need to use the summer formula in the silver bottle and in the winter you use the white bottle. Just my humble opinion.
Sent from my SM-G900V using Tapatalk
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
I use the following in my 2012 L4600DT.
Winter I use the white bottle and summer the grey.
http://powerservice.com/psp_product/diesel-kleen-cetane-boost/
I have a measuring beaker with lines marked on it for my 2 size containers i use to put diesel fuel in. When I return from the store I had to my containers.
