Hi: I have purchased a four spool valve with float on each. I will be plumbing in my grapple with one spool, two rear remotes, and one spool in reserve for some future use. Power beyond from my loader valve will feed the pressure inlet on the new valve, and the new valve power beyond connects to the fitting under the tractor that the loader valve power beyond now feeds. I assume this is the three point.
I will put a tee at the end of the tank line from the loader valve, and connect the tank line from the new valve into the tee.
My question is, how much fluid am I going to lose when I open the lines under the tractor? Is it going to drain everything, or will it be a limited amount? Obviously, whatever is in the loader valve lines will drain out. Trying to figure if I should just drain the tractor totally (just did for fluid/filter changes) or catch what comes out. Thank you.
