I ended up buying the hoses locally. the cylinder and spool valve were NPT, no idea what the kubota was, but they had an adapter. All the hoses are JIC with NPT adapters. 2x 10' 1/2" JIC with swivels, 2x 5' 3/4" JIC with adapters.
$400 for hoses
$20 for hydraulic cylinder
$20 for spool valve
It works. Quickly remembered I forgot to tighten down a couple fittings. Need to swap the hoses on the spool valve. Also forgot I only tacked on the mounting bracket for the snowblower.
$400 for hoses
$20 for spool valve
