9960 MFWD, makes a clacking sound in reverse.
FSteveP
M9960D
Dec 1, 2023
California
I have a 9960 MFWD. When in reverse it started making a clacking noise, doesn't make it going forward. I sounds like it is forward of the transmission, but I can't tell if it is the front axle or the drive shaft.
Any ideas where to start?
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
I would jack up and support the front, then turn each front wheel and listen for strange noises. This should help you narrow it down.
SDT
multiple and various
Apr 15, 2018
3,348
1,125
SE, IN
Noise with FWA engaged, disengaged or both?
BAP
Dec 31, 2012
3,058
1,176
Check all the lug nuts for proper torque. Also, if you have 2 piece wheels check the bolts holding them together. Loose lug nuts or bolts holding the wheels together will cause noises like that.
SDT
Apr 15, 2018
3,348
1,125
SE, IN
Bingo.
