Hi all I have a 94 b7100 hst. I am experiencing continued travel either forward or backward, depending on direction of travel before letting off the pedal. I ve heard it can be adjusted but am unsure how. Any help would be appreciated.
Thanks Dylan
Does the hydro pedal return to center once you remove your foot? Probably not.
Recently, the pedal return spring on my 1993 B1750 (similar tractor) failed due to vibration induced metal fatigue. Without the spring, the pedal will remain in the position that it was last in after removal of foot for some time.
This failure is not uncommon after 25+ years.
Kubota changed the spring to a so-called "hose spring" sometime in the 1990s. The "hose spring" has a piece of split rubber hose inside the spring to dampen the oscillations, greatly reducing or eliminating the metal fatigue induced failure mode.
Both old design and new design springs are available from Kubota. If you buy a new spring from Kubota, be certain to get the later design "hose spring" (costs about twice as much) or insert a short piece of 3/8" fuel line hose inside the regular spring before installation.
You may also want to inspect the damper and replace it if indicated.
SDT
