9.5 -16 ags on a B7100D, are they too big?
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
9
Leafy England....
as in the title guys.
Are 9.5-16 ags on the rear of my 7100D going to be too big, we have some really wet areas here and need something a bit more serious to be honest.
I was thinking they should be fine on the basis that if i was using double rears (2x 7-16 ) per side that would be even wider.
I realise the rolling dia will be a bit more, but with 6-12 ags on the front they may still all be within spec.
any help would be great.
rob
johnb6100
woods rm48, 91 cummins,00 foreman,78bronco,86 4runner,88 bronco2
Mar 10, 2012
32
fayette county,tn
hey man, i just put 8.00x16 on my b6100. they measure about 30 inches tall. if u go look at the tire and wheel thread and find (new front tirers and wheels) there are pics of my rear 8.00x16 on my tractor. they work great and they are only about and inch and a half taller than my turfs. im not quite sure is a 9.50x16 is any taller, if it is it couldnt be much. good luck
76_Bronco
B7200 4WD w/FEL, 4' disc, 4' Brush Hog, 14" Plow, 4' Blade, JD 246 2 row Planter
Mar 28, 2012
182
Rainsville, Al
I too was thinking about putting 9.5x16's on my B7200 4WD so I could have a wider stance. But I quickly changed my mind because the 9.5's are 2.5" taller than my 8x16's and the rolling circumference is 7" longer. See link.. http://www.firestoneag.com/en/tire-finder/search-Compact-Garden.aspx So I have decided to buy new wheels(8.25x16.5) and R4 tires(10x16.5).
boxsters
Kubota B7100hst w/ loader , jd 757 zero turn
Apr 15, 2013
14
Redmond WA.
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
If you have room to go to the bigger tire AND change the front tires accordingly keeping the "RATIO" the same you can change it. The 9.5-16 requires a wider rim and the offset of the rim would have to put the extra width to the outside ( reversed offset ) so that it wouldn't rub in the inside.
Keep in mind the overall width in comparison to the width of your bucket, backblade, mower etc because you don't want the tires running outside of them.
Al
kcw12
B7100HST-D
May 21, 2013
36
Eckerty IN
Yes where did you get them wheels. and what are those tires. Looking to do the same with my b7100 although i have a 6 lug front pattern.
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
The rears are 16x8 D window for Dakota truck, 6 on 4.5
The rear hub has to be redrilled as the 6 bolt hole circle is metric.
The front are golf cart wheels that were 2+5 offset that I changed to center offset.
You won't find a D window with a 6 bolt circle on a 12" wheel.
You could go with a 5+2 offset and have a custom 2" adapter made (6 bolt to 4 bolt) that would bring you back to center.
3,760
OH sure SS CRAGARs they looked better on my 35 coupe,,lol
