7040 loader raising issue
rheard77
Jun 19, 2021
Mississippi
My 7040 tractor loader is raising a lot slower than normal. I just changed the hydraulic filters and saw basically no change in raising speed. Ideas?
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,298
184
Coyote Flats,Texas
Welcome to OTT
Check all hyd quick disconnects associated with FEL to be sure they're seated properly. It's possible 3 pt feedback rod is out of correct adjustment & if 3 pt is fully raised 3 pt relief valve is opened causing loss of hyd flow to FEL.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
If the three point control is fully in the raise position it can affect operation of the loader.
Captain13
Feb 27, 2019
530
173
Kathleen, GA
Draft position lever can also affect lift speed And curl speed. Discovered it last week on my 7040. Draft lever was all the way down and lift/curl was very slow. May have had three point all the way up, but once I backed off the draft control, all went back to normal.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,298
184
Coyote Flats,Texas
I agree if 3 pt feedback rod isn't adjusted correctly 3 pt when fully raised will cause relief valve to open robbing pump output & cause hyd oil to heat & as Dave stated remote control lever needs to be in neutral position when not in use
