6 1/2' king kutter disk
bucktail
Jun 13, 2016
1,255
190
MN
Will an L1500DT pull a 6 1/2' tandem disk?
6,327
That depends on how you have the disc adjusted to determine depth of cut and what type of disc you have on it.
DT makes a difference, and would pull it. Just may have to go over the area with a shallow cut and then redo.
Wbk
307
St Adolphe Manitoba Canada
I had a 5 ft. double disc on my bx 2660 with a loader. it has 25.5 hp and it took it all to pull it and i had to have the loader on to turn or it would slide. Our soil is fairly heavy in our area. Hope this helps Barry
bucktail
Jun 13, 2016
1,255
190
MN
I found it on Northern Tool's website. They recommend 35hp & up. The shipping weight is 790 lbs. and I'm pretty sure the 3ph will handle that. I'll keep my eye out for a 4 1/2' one. They recommend 20hp & up for that one. I'll be running it in sand and light loam and I think that the tractor weighs enough and has a stout enough drive train that I can shift down and make up for the 5 hp deficit
