4400 fuel problem
snoman
4400L
Feb 21, 2014
ashland nh
I have a 2012 4400 L . The fuel filter runs out under load. If you wait about 3 minutes it refills and the engine runs again. the machine has 50 hrs on it. what advise can you suggest . The machine is 1 mile in the woods
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,180
117
Coyote Flats,Texas
Check to be sure tank is venting. Try running engine with fuel cap loose or off. Check for a good fuel flow from tank.
Bluegill
Jan 11, 2012
1,560
Success Missouri
If the tank vent is good, then you have bad fuel or something growing in it. Change the filter, the fuel and treat it, might need to clean out the tank...
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Also try to crack the injectors and bleed the air out, sounds like there could be air in the system. Did you replace a fuel filter recently?
Tx Jim
Apr 30, 2013
1,180
117
Coyote Flats,Texas
If engine will run for 3 minutes I doubt seriously if air is in inj pump or inj lines. I still think it's a lack of good fuel flow from the tank.
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Wow 50 hours, you are basically talking a new machine here. I would disconnect the fuel line going into the fuel filter and see how quickly you can drain the entire tank into a container.
What kind of ambient air temperatures has the machine been exposed to?
