3rd Regen
sparky45
L 3301DT
Dec 5, 2018
248
51
SEDAN
@ 39.8 hrs my tractor L3301 just completed it's 3rd Regen. Disc'n and movin' about 9 ton of Clay.
turnkey47
L3901,farmi351 winch,land pride backblade and snowblower,bush hog sq60
Jun 21, 2019
fort ann,ny
i have a L3901DT and had my 5th regen yesterday at 60hrs,the only problem is that i have to bump the rpms up to 2800 before the rpm indicator stops flashing and regen takes place...i have read where most people only raise the rpms to about 2100 or 2200 and keep on working..am i doing something wrong..i use my tractor mainly for skidding firewood and snowblowing and keep the rpms at 1900 most of the time.
mdhughes
L3901DT
Dec 10, 2014
1,325
999
Ste Geneveive county, MO
It depends on what you are doing when the ECM calls for a regen how high you have to get the RPMs. I have been grading the private road and not have to raise the RPMs at all. But if I'm in the woods cutting firewood and taking logs to the shed to be bucked up and split I will have to raise them really high. It has to get the DPF hot enough to burn the extra diesel that it is injecting to burn.
turnkey47
Jun 21, 2019
fort ann,ny
thats what i thought but wan't sure..thanks for the info...probably wouldn,t havehad to raise the rpms that much if i was brush hogging...was in the woods when it happend
sparky45
L 3301DT
Dec 5, 2018
248
51
SEDAN
Well, I guess that I'm in a select group. Just raised the RPM's to around 2200 and kept on loading Clay.
Bmyers
May 27, 2019
3,450
4,303
Southern Illinois
I'm a little over 36 hours and haven't had my first regen yet. Getting close, last time I looked at the regen screen, I was at 90+ percent.
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
44
on my non kubota.... (kioti) its regenning about every 40hrs.
if you hit the regen button for it to auto cycle? it jumps up to 2700 till its done.
i run my tractors right where the indicators say to for everything work wise & never below 1800 even if doing light non PTO work.
